Hello Everyone, I am try to clean up some of the old parts I have,
1) Rays Wheel Lug Nuts Duralumin Lock & Nut Set in Red. Items are in good condition, the color is fade. I am selling due to changed to the Works one. $75
2) TOG Brand New Test pipe. This is the 3" Stainless Steel Test pipe, this item is suitable for Silvia but they told me that it will fit in my Skyline. It contains gaskets, bolt to install. Was plan to fit in my car but plan has change. Brought it for $130, Selling it for $110 as they are on sale at eBay for $123.5.
3) Blitz Sus Power intake for ECR33 and ER34. This is the stainless steel mesh design, once it is install you can hear the nice suction sound. It is in a good condition some core bent a bit, sell due to upgrade to the latest model. Come with all the bolt and original mounting to avoid defect. Looking for $120
As I am not always log in to SAU, please send me a text to 0414963354, items are located in Brisbane, will accept reasonable offer, can post interstate with buyer's expense. Thank you.
Edited by Alfred Y
  • 4 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
