I recently took my manifold off to easy out a stud that snapped inside the the head thanks to the previous owner. When taking off the turbo I tried unscrewing the 24mm water return banjo bolt and didn't realise the pipe was bending, when I realised it was bending in I tried to put it back into place it snapped.
My questions is, how does water return work? Where does it go? Also the pipe feels really loose and can move around, but I cant seem to take it out, does this mean it's damaged? I was planning just to run some an6 braided line I had lying around and just join the pipe back together with that.
https://www.sau.com.au/forums/topic/452772-water-return-line-from-turbo/
If the factory hard lines are bent i'd suggest swapping to some braided lines, it's probably good preventative maintenance while you're in there with the age of those lines too
As for water return location, it really depends on your engine. What engine do you have?
yeah that's a really common issue when they haven't been apart for a while.
what car? I know the gtr ones are readily available from Nissan at a reasonable price....because I've had to replace a few over the years for the same reason
that hard line connects to a rubber line that then runs across behind the back of the head/cam cover area and then does a 90 degree turn and connects to the water feed which is on the intake side of the head.
Its a fun job to replace it but possible. I remember that my best friend in this job was a pair of very long needle nose pliers.
From memory I even did I write-up of doing this job or commented on it in detail somewhere circa 2011ish.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
