Hi guys. Big fan of forum, first time poster and need some help.
I currently have pedders comfort gas shocks with pedders low springs and aren't very happy with the way it handles bumps. Have been scouring through advice others on here have been given and am thinking of getting some bilstein dampers and king spring lows (but open to suggestion) and was just looking for some input into the difference I could expect in ride and height? also what parts I would need to complete the assembly? Could I use parts off the pedders?
Thanks in advance
https://www.sau.com.au/forums/topic/452796-r33-gtst-suspension/
OK, so these are R32 springs, not R33. But shown are both GTSt (left) and GTR (right clean and dirty) front springs.
They are progressive. As are the rear ones that I didn't take any photos of. Kings, obviously enough from the colour.
Edited by GTSBoy
I have no knowledge of the Pedders stuff. I have sworn black and blue that I will never use them again after one of their six-toe moron operators warped a brake drum on one of my cars about 25 years ago. Rattlegunned up the wheel nuts in circular order.
Just about any suspension supplier/workshop will be able to supply you boots and stops.
I won't waste any time on this; call king springs and ask their tech dept about the spring rate of their r33 springs (as I did when looking at buying a set of their springs a while back). Couldn't remember 100% which was linear but yes it is fronts, thanks for posting pic up gtsboy.
I thought the softer part of the rear springs are meant to bind when installed with the weight of the car on them anyway? Effectively making the softer section helper springs to ensure that the springs stay captive at full droop since the rear shocks are so long
By the way. I load tested them. They're 5.something kg/mm but they're not linear.
load-of-bullshit tested them, more like. If you did actually test them then you fu*ked up the test; cos they're linear.
See how the diameter of the coils changes? Also changes the spring rate
nope. The diameter of the coils is irrelevant, it's how much they compress under load, eg a 6kg/mm spring compressing 1mm under 6kg of load. I know this to be fact, having specifically asked King Springs, MCA Suspension, BC Australia etc this question, when asking about any difference of spring rate between the wider springs found on stock suspension and the smaller diameter coils found on aftermarket coilovers. I'm surprised you didn't know that, being an engineer and all.
pretty much yep, more a dual-rate spring rather than a true 'progressive' where the coil spacing more evenly changes top to bottom. You can see this on the Tein website where they list the different spring rates for the same springs. But still classed as a progressive spring.
Varies with D cubed.
k = Gd4/[8nD3]
Where:
k = constant, pounds of load per inch of deflection
G = modulus of rigidity of spring material, pounds per square inch
d = wire diameter, inches
n = number of active coils, which is the number of coils subjected to flexure (always less than the total number of coils)
D = mean coil diameter, inches = Outer Diameter - Wire Diameter
You Manuel......are a waste of internet space.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
