Hi all,
Firstly, I've done a fair bit of research on trying to find the issue before posting this, but haven't managed to find any useful information.
I recently converted my car to manual which involved pulling the engine out along with the gearbox. We pulled all electronics out and I have a feeling I've forgotten to connect something, but I have no idea what..
The AC works when I bridge the relay with a wire, I bought a new relay because I thought that was the issue but turns out it wasn't. The connectors at the back of the climate control unit are all connected.
Any ideas? I feel like it's something simple :/
Thanks in advance :)
https://www.sau.com.au/forums/topic/452879-r34-25gt-aircon-not-working/
When you say it works when you bridge the relay, how cold is it, as it might be low on gas and so by bridging the relay you bypass the pressure switch.
We just filled it with gas and it's still doing the same thing. We only temporarily bridged it to fill the gas just in case the pressure was too low for the pressure switch to work. We also needed to bridge the blower for the condenser as it wasn't working either. Basically, my whole air-conditioning system is down. When pressing the "AC" button on my Climate control unit, nothing happens.
When we did bridge it, the aircon was freezing cold. Works perfectly when bridged haha
When converting the car to manual, the auto-loom was hanging down and instead of cable tying the plugs which weren't being used (all of them were useless), we cut the loom and bridged the inhibitor so my car would start, all other cables are taped up and not connected.
Hope that helps!
Unsure about 34 yet on a 32 and 33 the fan is just an overheat fan and isn't on with ac unless you mod it.
https://www.google.com.au/url?sa=t&source=web&rct=j&ei=lt28VI-DGION8QXFrYHICw&url=http://www.nicoclub.com/FSM/Skyline/R34-Workshop-Manual-English.pdf
Page 150 is a wiring diagram
Having a quick look, maybee in the harness that's been disconnected is were the wiring for the pressure switch runs, yet having not looked over the ac on a 34 yet I can't really say
I'll use a multimeter tomorrow and try and see if it's any of the wires in the loom which I cut (trial and error, hopefully I don't blow anything up). If you find anything please let me know! I'd rather not do what I'm thinking of doing lol.
Thanks for your help :)
Pins 57 and 48 on the engine ecu should goto the pressure sensor. I'm guessing thats the issue yet it's only a guess, if they both have continuity to the sensor then I'd be checking that pin 9 on the dcc unit goes to earth when ac is turned on, and that pin 21 and 14 on the engine ecu both goto earth as well.pin 14 on the engine ecu should also goto the ac relay that your earthing out. That could also be over in the wires near the auto wiring.
I'd be checking all the wiring that was left off from the manual conversion to see what has continuity to the ecu and to what pin
Edited by Scott Black
Will give it a go and let you know how I go, thanks for your help! :D
Ok so I did a diagnostic test on the climate control unit. The error relates to the "intake temperature sensor", any ideas?
FYI, I pulled out the heater core etc (behind glovebox compartment) because one of the pipes the coolant runs through had a crack in it and was leaking coolant.
ok, it looks like thats the sensor that sits on the ac evaporator, the ac evaporator sits next to the heater core, and i think it uses that sensor as the thermistor/thermostat to control when the ac cycles on, and if faulty would cause the ac to not run, if you checked pin 9 of the climate control unit and it doesnt goto earth when you turn the ac on, then thats going to be your problem.
That's the reason my air-con wasn't working, that plug which is circled in red was disconnected :/ such a pain in the arse to get to but i got there in the end :D from what I know, that plug was the intake temp sensor.
  • 11 months later...
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
