Originally posted by Jay95R33
That air flow conditioner may be a little device to lean the mixures out a little.  R33's run pretty rich usually.
Do a quick search through goggle and see what pops up.
You gotta love bonus bits.
Yeah, after moving through the results I finally found an english site with an explanation... It is indeed for adjusting air/fuel ratio.
  • Replies 345
Originally posted by GunMetalR33
Hey J & James,
Give us a call when Shell's pod is to go on. I have about 70 IOU's for you guys.
For Info James & J have so far installed the following for me:
1) boost controller
2) 3 inch turbo back exaust
3)Pod filter and bracket
4)pluged my BOV
Just let me know when and where?, we can have a Bar-B-Q and some cold ones
My pod is already on :P
and no, J&J (Pty Ltd) didn't do it hehe
hey, jnr_j.....I work in Fyshwick too, where are you at? I'm down in Wiluna St.
Hey folks. Been lazy and haven't said g'day on the roll call to date......so...Hi!. I own the white 33 in my avatar. I live in Qbn and work in the ACT. I'm of the older variety of humans, and have a family which keeps me pretty busy. I'll try to get to a meet or cruise at some stage, but my life is pretty hectic and I don't often get any spare time.
Anyway, I'm always out and about around Qbn and ACT so if u see me flash....your lights!.
Oh, and for the keen eyed of you....I know it's not a GTR....the car came with the badges....sue me!. I am trying to get a grille to fit in the space with just a Skyline 'S', but having a little difficulty. I have also had the badge off, but it looks sh%t. Any help on the grille would be appreciated.
cheers to all Ozzy
Hey Jayson....how ya doin? I work and live over QBN way. I do get out to Tuggers pretty often...mostly to Bunnings or the Hyperdome when the MRS drags me over there to look at plants and girly stuff. It was you that sent me the CAI stuff wasn't it? Thanks for that. I often see 'Lines around and give 'em a wave and flash (of the lights)...It's a great community feeling amongst the owners. Anyway, Keep in touch.
cheers Ozzy
Hi guys,
I have left this post in the wanted to by forum but it makes things easier for all if the parts are in canberra.
Anyway, I am after side skirts, GTR style RW and some springs to lower my ride about 20-30 mm that would fit over standard struts.
Ohh yea I would also like to get my hands on a turbo timer, getting sick of waiting for the car to cool.
IT would be great if any body could help me out
cheers...
Ps. love the flashing, keep it guys
  • 4 weeks later...
Hey guys, I just bought myself an R33 last weekend up in sydney so i figured i'd have a look in at the forum. I traded in the old kingswood, but didnt get much :devil:. i live over at the uni, i've seen a few other's around campus, but i dunno if any live there.
Terminal - cool, welcome to the forums.
Got any pics of your new car?
J
I should probably formally introduce myself as well. I bought an R33 the other week. I'm quite happy with it and am having heaps of fun with it.
Terminal, which uni you at? I work at the ANU, I've seen another R33 around don't know if it's yours though.
Here's a pic of mine.
I've only had mine for a week, I live over at Johns, so i park in the ressies carpark. mine's similar to yours FunkBrother, but different rims. I've got NSW plates as well.
i've got a dodgy pic my mate took on his phone. ill get some better ones when i find my camera (its under all this crud in my room somewhere)
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
