hey guys, does anyone have rough figures of what the follow cars with the following power can do in a quarter mile?(power = @ wheels)
gsts vs gtr @ 200kw, 250kw, 300kw, 350kw, 400kw
ie: 200kwgtst = 13s
200kw GTR = 12.4s
yes of course every car will be different, but just rough estimates of each will do
would be interested in users posting their 1/4 time and kw@wheels(figures that are close to 200-400kw's@wheel)
also state tires used please
just wanna see how much 4wd is better:P
heheheh
cheers
AssM@N
https://www.sau.com.au/forums/topic/45322-kwrw-kw4wd-scaling/
I've seen R33 GTST's in Sydney with exhaust, fmic, power fc run 12.9-13.9 and I've also seen GTR's with the same mods run 12.4-13.4 so I'm thinking at best 5 tenths different
i assume this time gap gets wider as the power increases.........
would like to see direct comparisons of kw ratings as stated in main post
that doesn't show me much
it only tells me time
not engine kw or what wheel drive
read the main post of what i want.... to compare rw and 4w
The list I linked you to ( http://skylines.pnc.com.au/drags.html ) actually tells you the model of Skyline (ie R32 GT-R, R33 GTS25t etc.) so if you know your Skylines you'll be able to figure out if it's RWD or AWD. AFAIK not one of the entries on that list uses RWD only if they have AWD and nor do any of the RWD guys have AWD transplants. If your not sure what model Skyline came with AWD then do a search.
As for rw/awkw levels, most of the entries on the list have this info in there sig's or listed under their profiles somewhere - try a search and see how you go. All the info your seeking is already on this forum in one way or another. It may take a bit of a search but you'll find it. Have fun :cheers:
You can get a 2WD to hook up pretty well, but at least it won't have the driveline losses of a 4WD at the high end of the track. Or weight.
Edit: and there's no way that "400rwkw" car has that much power. If it did it would have run alot more MPH...
Why would you assume that, do you think the only cars that are quick down the 1/4 mile are AWD?
because the more power u have, the more tranction probs u are gonna have........
never said ONLY AWD is fast;) just trying to find the disadvantaged time of traction loss or traction gained from AWD
as u stated: 12-13s on gtst is disadvantaged about 0.5s
As for rw/awkw levels, most of the entries on the list have this info in there sig's or listed under their profiles somewhere - try a search and see how you go. All the info your seeking is already on this forum in one way or another. It may take a bit of a search but you'll find it. Have fun :(
oh didn't click on the names, lol
from what im seeing so far
~300kw@rw will get u abt 12s on the quarter
but 2rismo has 200kw and still got ~12, maybe good launch + tires, etc
so ugh.......
The USA dynos factor a much lower drivetrain loss than our Aussie dynos. As a rough example (ie using totally bogus figures) ...
Australia: 250fwhp ='s 170rwhp - results in a 14.5 @ 100mph 1/4
USA: 250fwhp ='s 220rwhp - results in a 14.5 @ 100mph 1/4
It doesn't matter as long as your comparing apples to apples (ie US dyno figure vs other US dyno fig's). Compare Aussie fig's and US fig's and it won't add up.
My car makes ~470rwhp on a US dyno, woo hoo! :cheers:
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
