I first noticed the knock (which isnt very loud) when I was in gear and clutch out, just slowing down. The whining was been there for a while and suspect a belt tensioner needs replacing, but I have no idea what this knock is. It can only be heard when I back off the accelerator.
Here is a video:
yep, big ends, the more you drive the more damage your doing, if you strip it now you might be able to get away with linishing the crank (or maybee machine to undersized )and new bearings, if you keep driving, (maybee already to late) you will destroy the crank, rods, even have the motor let go and leave you stranded, pretty much if you want to rebuild, the more the motor runs the higher your bill gets
That's f**ked, just got the car, the funny thing is it only started making the sounds after I dropped the oil (Which was SO filthy and full of metal) and put fresh golden stuff in it.
Would the be damage to the head as well?
Also I was planning to drop this in: http://www.ebay.com.au/itm/RB25DET-New-Forged-Short-Engine-RB25-Block-Bottomend-Race-Drag-Drift-/371239977607?pt=AU_Car_Parts_Accessories&hash=item566fa08287
Would the be fine with the neo head?
If the motor let's go it will damage the head, if metal shavings go up to the cams it will damage the cams and the head, the previous owner probley put a really thick oil in the car to mask the noise so he could sell it to rip someone off into thinking the motors fine.
Yup after 25,000 in my GTR I had the same death rattle. Be careful I didn't notice and was boosting around (music going) for an afternoon and that was enough to bend the crank (ruin the journal) and crack the block - I was running 340kw at the time
I also had to recon my turbos (new -5's with 4000km on them). Head was fine though was pretty happy about that. Also had to replace oil cooler core as it could not be cleaned.
good luck.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
