This question has been asked a few times but no direct answeer.Bled the brakes four times not a single bubble came out after the third time. I rebuilt my calipers and put new brakes and rotors.
what do i do to bleed the master cylinder as the pedal is very soft goes right to the floor but somehow manages to stop the car. Heard some say i push the pedal to the floor and someone cracksthe bleed nipple. Looking aroumd the master cylinder and couldnt find it .Any help is appreacited trying to avoid a shop doing this for me.
https://www.sau.com.au/forums/topic/453542-brake-master-cylinder-bleeding/
Engine off when bleeding.
Someone pushes the pedal, someone else cracks the bleed nipple open, leaves it open till the pedal hits the floor, close the nipple, lift the pedal.
Check your ABS which also should have bleed nipples.
Got sick of the soft pedal feel so got a bit innovative. Made a pressure bleeder. Initially it was a fitting to a spare lid.The seal wasn't right enough so fluid spilt out. So ended up making a chain pressed perspex with rubber to seal. This worked a treat managed to pump the system to 13 psi and cracked all this zero bubble came out.
Before this I took out the two lines that go to the ABS unit and got an assistant to depress the pedal to squirt fluid then stuck my fingers to block the holes then got the assistant to release. This was done about four times. My pedal was still soft.Then my old man told me to find a secluded area where I could lock up the brakes once or twice.This worked a treat as there was air in the ABS unit.
Proper way to do it is to use the consult. But Nissan will charge me $300+ for that.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
