You will need deep pockets too thanks to postage. Just for an aero front bumper it was about $320 just for postage for snail mail (container).
I have been keeping an eye out for aftermarket M35 kits in Australia for 2 years now so good luck.
Good luck with that, it's going to be very hard since the car was never sold here.
Only reason I'm asking to see if there's anything in Australia is because there was a Balsarini bar and grill for sale on here a while back.
I can get various other kits from importers but I think the Balsarini kit looks the best by far. Only downside to this is that G - corporation the manufacturers of the kit discontinued them a while ago.
