Anyone know anywhere which sells LED brake (boot) lights for a 34?
I've read this: http://www.sau.com.au/forums/topic/371044-diy-led-tail-light-and-brake-light/?hl=+r34%20+led%20+brake%20+light
But I don't have the best luck when it comes to DIY stuff.
Unless there's an easier way e.g. simply changing the bulbs
Cheers
https://www.sau.com.au/forums/topic/454302-r34-led-brake-lights/
  • 1 month later...
Thanks.
Unfortunately the owner of the shop messaged me and said they wouldn't be available for another 2 weeks.
It's been over 2 weeks, so I'm bumping this in case anyone can share other sources.
Marcus, would it suit nismo R34 Leds?
Sent you a pm but best light to suit Nismo Led tail lights are the ones made by Qest Japan.
http://qestjapan.com/itempage/r34/qj-r499.html
Picking up a bunch of these next month as back in Japan for some late spring/early summer drinking !! :cheers: :cheers:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
