hello there ladies and gentlemen, im new here, I have a few questions for you guy's/girl's. does the rb20 cylinder head bolt onto the rb26? The story is im doing up an a 1965 xp ford falcon and instead going the v8 route I would like something different, like putting in a turbo rb26. The way the rules and regulations are I can either put a non forced induction engine upto 5 litre or go forced induction upto 3 litres. So any advice an help on what to look out for on the rb series engines would be fantastic thank you
https://www.sau.com.au/forums/topic/454394-newbie/
Well to be honest I don't know if they will fit - probably with a bit of work but its one of those why bother things.
Not sure that many people would have ever tried but RB25/20's & 25/30's exist so you would think you could get a 20 head to fit on a 26 if you really tried.
But:
The Rb26 head is a pretty good thing and given that most RB26's fail in the bottom end I would recommend you go looking for an Rb26 head.
As for the flow thing, no.
The car a 2 or 4 door?
https://www.sau.com.au/forums/topic/454394-newbie/#findComment-7490356
4 door xp sedan, thank you djr81 for your reply. the aim is have something different with reliable horse power, and drivable , few of the ford falcon boys are a bit upset, reckoning im ruining a classic car and ricing it up but ive nothing but good things about the rb series engines that they make good reliable horse power, the power im chasing is around the 350 to 400 mark the car doesn't weigh that much so it would be a fun car to drive around
https://www.sau.com.au/forums/topic/454394-newbie/#findComment-7490813
Yeah can understand why. Wouldnt an XR6 motor out of, say, an EB be better?
Honestly having owned too many GTR's and RB26's they really aren't as brilliant as people make them out to be. I don't know that I would recommend one for a conversion. Not least for the reason that (From memory) the exhaust is on the wrong side for a Falcon.
https://www.sau.com.au/forums/topic/454394-newbie/#findComment-7491970
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
