The speed of the shift is determined by the ability of he synchros to engage the gear, not the throw of the lever.
Therefore, with a short shifter, the speed is not faster, however the wear on the synchros is higher. Lose lose scenario. And costs money. Lose lose lose.
If you want to get a more solid feel I would recomend the nismo solid shifter it's only a 10% shorter throw but its a solid piece so it will fix the slop in the standard shifter. I really can't see a 10% shorter shifter wrecking your synchros after all my GTT has had a proper short shifter in it for nearly 8 years and the gearbox still works fine.
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
