Hi All,
get a piece of History! The original JUN Supra wheels are available.
Specs:
Yokohama AVS Model 6
18 x 8 +35 (245/40/18 Yokohama Semi Slick)
17 x 11 +53 (315/35/17 Yokohama Semi Slick)
Price:
$2499 lcoated in Sydney or can deliver anywhere at your expense.
The wheels are in excellent condition as apparent by the pics. Rear tyres are almost new fronts are about 40%
These are light wight semi forged wheels, and it clears big brakes too.
Here is the JUN Supra in action:
Video
Pictures:
10872832_991508030862820_773688240800291
10690260_991508110862812_403353558945107
10376840_991508104196146_175297356924201
10922420_991507997529490_330102085309673
Rear Tyres:
1782106_991508100862813_7495107008770384
Fronts:
10433203_991507877529502_437524590474685
10806206_991507604196196_678307737302058
Only real blemish on one wheel
10942743_991507644196192_688091263858285
https://www.sau.com.au/forums/topic/454596-jun-supra-original-avs-wheels/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
