Guys, I've got let go of my skyline. Beautiful beautiful car, to cater for a growing family and a dog!
In fact, I don't mind swapping for a wagon, so send me your offers!
I got this car listed on Carsales for $16,990 .. but $16,000 here.
Clean and hardly driven!
Year: 2003
Make: Nissan Skyline
Model: V35 350GT
Km's: 114996
Reg: Sept 2015 ?
Price: $16,000 (will consider trades for wagon with similar power)
Contact: Raph - 0400 868 580
**New Notes
- I just serviced the car Sat 07/02 and replace the battery. So new owner, nothing to worry about for at least 2 years.
- Forgot to mention, Long Rego. Sept 2015.
Exterior:
- Updated Projector Headlights with upgraded ballast Hid 6000k. This is the best feature of this car. See if from the photos
- Genuine KenStyle Front Bumper Bar with fog lamps
- G2 Racing 106 HB 20" Chrome wheels
- 20" 245/30 & 275/30 R20 Achilles ATR Sport Tyres
Engine:
- Skunk2 Plenum Spacer
- Custom Carbon Fibre Cold Air Intake
- Full Xforce Setup including Custom Manifolds and Full 2.5 inch xforce twin loop exhaust system
Interior:
- Asuka Tv Tuner
- Hidden Reverse Camera linked to pop-up LCD monitor on dash
- Main center console fully converted to English
Suspension:
- Adjustable Stillen Sway bars on Front and Rear
- Complete replacement of OEM front Suspension Bushes to EnergySuspension PU
- Circuit Sports/Alutec Front and Rear Underbody Brace
- Dale's special Front Mid Underbody brace.
- NRG Front Strut Brace.
https://www.sau.com.au/forums/topic/454776-v35-for-sale-hardly-driven/
I confess to not knowing much about the V35 market and what's desired, but, seems pricey for an auto - there's a 6 speed manual selling for $10k on here. You've only got two pics up and they are really the same angle. If you get someone good with a camera to photograph it from all angles in nice lighting including interior shots that will far reduce people dismissing the add. Hope that helps and GLWS.
Good advice Birds. I did see the manual car going for $10K but it didn't have as many mods as mine.
Would love to see my car but not at a fire sale price. Dealers are still listing theirs at nearly $20K.
Car has been looked after, serviced regularly but everyone says that.
Come and see if you are interested. Now.. more photos.
So nice, absolutely love it - only thing holding you back (at this price) is the mileage. Don't worry about what anyone says about it being auto... V35's drive far better in 5 Speed Auto than they do 6 Speed Manual...
...and anyway, those who are interested in your car and the person who purchases it will be specifically looking for an auto (and not interested in doing a conversion to manual most times)... If it was a cheap R33 / R34 Turbo Automatic it might be different (because a lot of people want to convert them) but with V35's its different.
Good luck with your sale, I'd buy it! But I just sold my V35 and am now importing a V36 :P
Edited by Sikahalv
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
