Below are the simple rules for the use of the Stagea Parts For Sale section.
Any users that choose to ignore the rules as below will either have their posts or threads removed/edited, or may receive a warning. Once a certain warning level has been reached, a user will be banned for 2 weeks. If a further ban is incurred through the warning system, a permanent ban will contracted.
THE DO'S AND DONT'S OF THE SAU CLASSIFIEDS!
Sellers
1. When starting a new thread, you must include a set price, or at the very least a ballpark figure that you are looking for. EOI's are not permitted
