Up for sale I have stock parts, all in good working condition, all parts came off a 1997 R33 GTST.
Make an offer, reasonable offers wont be refused.
Standard Series 2 rear wing in silver (working break light included) $40
Aftermarket fiberglass Du-Luck side Skirts (painted silver, small crack but cant be seen when fitted) $80
Boot Lid (no wing, no lock, White) ***FREE***
Standard fuel pump $10
Standard exhaust cam gear $10
Standard injectors $90
Standard rear sway bar $20
Standard ECU $120
Standard cam shafts $50
X-Force muffler $30
Rear series 1 garnish $10
Standard coil packs $120
Standard indicators front guard $10
Standard rear rotors $15
All parts located south east Melbourne
Prefer pick up...if not buyer can arrange postage
I have photos of all the above parts...message me if you require pictures
Thanks
https://www.sau.com.au/forums/topic/455124-r33-gtst-parts-melbourne-cheap/
***** NEW PRICE LIST*****
Standard Series 2 rear wing in silver (working break light included) $30
Standard fuel pump $5
Standard exhaust cam gear $5
Standard injectors $75
Standard rear sway bar $10
Standard ECU $80
Standard cam shafts $30
X-Force muffler $15
Rear series 1 garnish $5
Standard coil packs $75
Standard indicators front guard $5
Or $ 230 for the lot
All parts need to go moving house and dont have the room
Cheers
BUMP
*****UPDATED LIST*****
Standard Series 2 rear wing in silver (working break light included) $20
Standard ECU $60
Standard cam shafts $20
Standard coil packs $60
Standard ECU $50
Standard coil packs $50
********** UPDATED PRICE LIST **********
Standard coil packs $40
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
