Somewhat due to my new job and busy schedule the Skyline has just ticked over 3 months out of rego, and into the dreaded blue slip territory... deciding what i should do now..
Is it more common to be buying a trailer or to hire as needed?
Also what are people generally paying for a lower end trailer?
https://www.sau.com.au/forums/topic/455453-to-trailer-or-not-to-trailer/
If you're only towing a few times a year, hire trailers will most likely work out cheaper, and you don't have to worry about storing it somewhere.
HOWEVER, hire trailers are like hire cars - nobody loves them, and they get severely punished. Also they are designed for muppets who decide to load a landcruiser onto them, so are built like the proverbial brick sh*thouse. This means they weigh heaps too (900kg is not unusual for a hire trailer).
You can buy reasonable brand new trailers for $3k and up, though IMHO a good quality one will probably cost you $5k or more, unless you know someone with good welding skills. There are some good second hand trailers around, and if you know what to look for, you should be able to get a useable one for $2k (bargains come up every now and then). I wouldn't buy one for any less than $2k, as it will most likely be shagged.
You can occasionally get fairly cheap good trailers for small / light cars, but for something like a Skyline you want to make sure the trailer is well built and it needs to be more robust, which in turn means heavier.
Just as important is what you're going to tow with. There's a very long thread about tow vehicles - it contains lots of good info about trailers, tow vehicles, and regulations surrounding towing.
Finally, once you get a nice trailer, NEVER loan it out. They have a habit of coming back damaged.
Bought my trailer 2nd hand, 6 months old and never used. Keep an eye out on gumtree for somthing as they pop up but sell quick.
I used to rent but it's dead money.
And that pic above is 100% correct. Gotta swat away the people wanting to borrow your trailer.
  • 4 months later...
thread revival - will be looking to buy a trailer in the next month or so - has anyone bought new recently in the sydney area? if so where from and would you recommend?
will be looking for something that is fairly light and easy enough to load/unload alone
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
