Hey guys,
So I'm moving back to Canada so i am selling a whole bunch of Skyline stuff I have accumulated over the years. This is basically going to be a "make an offer' kind of situation because I would rather get some money then potentially scaring off a buyer for something because I list some fabricated price. Trust me though its going to pretty well be your offer takes the item/s.
Here are some pics to look through rather then try to list everything. But the few bigger items are
R34 GTT cluster 1x auto 1 x Manual both around 130Km
R33 GTR turbo's came off my running GTR a few years ago, could deff go straight onto a gtr with comp covers put on.
The side mount intercooler is either off a GTT or a stagea I'm not sure.
The rims are a japanese made 17" that came on a stagea i purchased and they have winter tires on them with plenty of tread but a few cuts in the tread faces. will still be safe to drive on.
R34 GTT front brake callipers. awesome upgrade for stagea's
The coils are from a R34 GTT with 110,000kms that I stripped, I honestly don't know if they were missing or not, but i would say if you go into it buying them assuming 1 is low then you will be safe. and way better off then buying retail haha
have a Cat back stainless exhaust. 3" with magna flow straight through mufflers. just needs 1 weld and it will be a good exhaust for 275+ RWKW
Everything drive related from an Automatic R34 skyline Trans, converter, flex plate, tail shaft, harness, shifter etc. wasn't slipping, just had trans service.
post-59170-0-18092700-1428815674_thumb.jpgpost-59170-0-57735600-1428815710_thumb.jpgpost-59170-0-36398200-1428815767_thumb.jpgpost-59170-0-86661300-1428816067_thumb.jpgpost-59170-0-87117200-1428816480_thumb.jpg
Anyway, have a look and text me if you want anything, All items are in Melbourne SE suburbs , Ferntree Gully. and I can't be bothered with freighting stuff as I'm leaving in 4 weeks and have enough shit to worry about.
Chris 0four12eight13551
Im not sure to be honest, i Know its a straight through stainless steel, I will have a look at it tomorrow and see if the muffler has any model numbers on it.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
