Adam I'm not sure if you really are this ignorant, or your trolling, but you do realise that you are being given sarcastic answers because questions you are asking are so obscenely stupid, right?
The answer is No you should not change your AFM or injectors without a tune. The only thing you can do is increase your boost a little bit up to the point the car starts to run too lean to be "good" for it, but even then you have to a have good idea of how your engine works to know when that point comes.
If you fit slightly larger injectors or increase the fuel pressure somewhat, you may be able to get more fuel under WOT allowing you to get even more boost and more power under the right lucky circumstances without pinging, but it will run like crap almost all the other time and will not be worth it.
Are you a backyard mechanic somewhere in Pakistan fiddling with all this stuff so you can be cool and drift like in the american movies?
    • Bought a v35, with blown head gasket. Looking for ideas what to do next? Rebuild, replace or swap??
    • I know -_- Oddly enough I went to a car show this weekend and not a single person made any mention of Nitrous... I did have to argue with a know it all that was convinced I had an RB26 head with HKS V-Cam as opposed to a regular VCT RB25 head, but what do I know. I think my HKS oil cap was throwing him off.
    • That seems like a lot more work than just using a second jack under a front tow hook to raise it enough to get another jack under it.
    • They're wonderful when only used to lift your car up an inch so a real jack fits under your front lip. Besides that, I've only ever used them on the side of the road.  We call them widow makers here.  Unfortunately, like I mentioned in another post, ramps are not an option for me due to generally working on my car once my kids are asleep. Cold starts, 4" exhaust and sleep rarely go well together. I honestly find using ramps a hell of a lot more work than what I'm currently doing anyways.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
