Hi Guys,
I'm reluctantly putting my now discontinued fixed back Recaro TS-G ASM limited seat.
The seat is absolute porn and in excellent condition. Here is a bit about the seat:
http://www.gotuning.com/product_info.php?cPath=29_154&products_id=201
Part of the ASM LIMITED series of original ASM tailored seats. Based on the new RS-G structural sports shell from Recaro Japan. ASM Limited Recaro products are produced by Recaro Japan specifically for ASM, they are not reupholstered by ASM.
The shining mesh silver cloth is adopted for this Recaro seat and greatly improves the feeling of luxury. Also features a Silver RECARO logo and Red double stitch that further improves sportiness. The seat side allows smoother accelerator, brake, and clutch action with divided leg support. Support has been improved to the shoulder with the addition by adding no slipping support. The angle of the back rest is the same as the popular Recaro SP-G. It is a very comfortable full bucket seat that firmly supports the waist surroundings. The RS-G ASM Limited seat suits many cars such as Altezza, Civic, Integra, S2000, Impreza, 350Z, RX-7, and Skyline.
Seat comes with a genuine Recaro ASM side protector which protects the seat when getting in and out.
It does have a genuine R32 GTR Rail which cost $400 however i might hold onto this.
Price for seat only $1000
Located in Sydney
  • 1 month later...
BUMP seat is back up for sale.
Price $1100 - Including a genuine Recaro rail to suit R32 GTR
will post pics more pics tonight however it is the same as the below:
Edited by The-Lowdown.com
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
