G'day folks,
Looking to clean the garage up a bit. I'll add photo's when i get a chance.
Feel free to make an offer on any of this stuff. I prefer pick up from 5169 Seaford Meadows for any of the larger stuff and if you require me to deliver anything to a depo please check how far it is from me and keep that in mind when you make an offer.
PM for more details if needed.
Cheers.
M35 Black leather drivers / passenger seats. Great condition. Comes with everything from when i had them replaced with R35 GTR seats. - $450
Stock exhaust - Taken off the car at approx 95,000kms. - $150
Stock suspension - taken off the car at 95,000kms - $200
Apexi N1 exhaust (just the muffler) 3inch inlet to i think 4.5 inch tip i think. With a polish would be perfect - $150
Stock M35 injector x6 (no rail) - $150
Stock blue M35 front bumper (has parking aid for added awesome) - $200
I'm sure i have more bits... I'll add what i can when i can.
Cheers.
Edited by Beregron
https://www.sau.com.au/forums/topic/456528-m35-garage-clean-up/
Ok picture time.
Reminder that it is very difficult to me (and not really worth my time) to deliver items to a depot. Also as i work over an hour away from home (Mon to Fri) there isn't much i can do about leaving items for a courier to pick up. I'm happy to try work something out if i can though.
I need to take a picture of the stocky front bar yet... which btw i also have a stock M35 grill also.
Oh and i found my old stock M35 intercooler. Feel free to make an offer on any of this stuff.
Cheers
Cheers mate.
It's my own fault for working so far away from home so i imagine i'll either store most of this stuff for if/when i sell the stagea or get a local sale.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
