G'day folks,
Looking to clean the garage up a bit. I'll add photo's when i get a chance.
Feel free to make an offer on any of this stuff. I prefer pick up from 5169 Seaford Meadows for any of the larger stuff and if you require me to deliver anything to a depo please check how far it is from me and keep that in mind when you make an offer.
PM for more details if needed.
Cheers.
M35 Black leather drivers / passenger seats. Great condition. Comes with everything from when i had them replaced with R35 GTR seats. - $450
Stock exhaust - Taken off the car at approx 95,000kms. - $150
Stock suspension - taken off the car at 95,000kms - $200
Apexi N1 exhaust (just the muffler) 3inch inlet to i think 4.5 inch tip i think. With a polish would be perfect - $150
Stock M35 injector x6 (no rail) - $150
Stock blue M35 front bumper (has parking aid for added awesome) - $200
I'm sure i have more bits... I'll add what i can when i can.
Cheers.
Edited by Beregron
https://www.sau.com.au/forums/topic/456528-m35-garage-clean-up/
Ok picture time.
Reminder that it is very difficult to me (and not really worth my time) to deliver items to a depot. Also as i work over an hour away from home (Mon to Fri) there isn't much i can do about leaving items for a courier to pick up. I'm happy to try work something out if i can though.
I need to take a picture of the stocky front bar yet... which btw i also have a stock M35 grill also.
Oh and i found my old stock M35 intercooler. Feel free to make an offer on any of this stuff.
Cheers
Cheers mate.
It's my own fault for working so far away from home so i imagine i'll either store most of this stuff for if/when i sell the stagea or get a local sale.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
