6 minutes ago, ElleAli76 said:
That's crazy ! How many K's
You've done now ?
4450km from collie to Gold coast. $630 in fuel. left saturday lunch and arrived monday night
4430km home. $730 in fuel. left friday arvo and arrived sunday arvo
  • Like 1
21 hours ago, ElleAli76 said:
Awwwwww yeah ! Nice one Trev , back for new year and your mother in law is coming here too yea? emoji7.png
nope no mother-in-law.
told her and brother in laws mum we couldnt afford to pay for their flights here and pay for a ticket to take them home on top of our costs. they are happy to visit another time. its a shame cos id love to bring her over here but flights have gone up 30% since we started looking late last year and once spending money is added we would need 10k+
[emoji22] awww so she's not coming here [emoji22]
Can you not book for one way ticket just for your mother in law ? Oh also are you going back in April for the Japanese New Year ? Or that's gone pass now?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
