Hey people my son and I cruized past in our blue r33 gtst tonight. I am a noob and have never been to anything or posted before.  I would assume that it was you guys out the front of super cheap at about 9:30pm?  I was going to stop and say Hi!! but my son was a bit nervous to get out of the car (He is 17 and thought you guys looked a bit dodgy  haha?.) We have only had the car since december and have been working on it flat out every weekend. So after 2 months and about $3 grand it has finally become a reliable vehicle.  I would like to be involved with the drive days cruizes and what not. I have wanted a skyline ever since the domination of Gentleman Jim and Skaifey in the R-32 GTR winfield nissan group A touring cars and have finally entered the realm of the NISSAN. Any feedback would be appreciated.
  • Like 3
P.S. I am old and crummy at the interweb thingy.  Since we have got the car we have done.  Enigine oil and filter,  fuel filter, Brake fluid bleed and replace, gearbox oil, diff oil with ford l.s.d paste and tons of figure 8's, full new 3" s/s exhaust with 100cell cat and 2xmagnaflow mufflers (i fabricated this), replaced front brake pads and discs (apr slotted), 4 new tyres, lifted the ride height, new coil packs and plugs, new radiator, outer tie rod ends, front castor arm bushes, Re-worked intercooler piping, fitted catch can, new pod filter, replaced snapped turbo studs, inner diff boots, re-wired under the dash, modified the throttle cable and bracket, New gear box boots, New rear speakers. etc.etc. My back is very sore but it was worth it.  Looking cool and going fast that's what cars are for.  My son and I have done nearly all the work in the driveway at home.  Madness!!!
  • Like 1
Yeah we got there late, So you guys don't have the everlast hoodies, singlets, shoes and thongs, mullets, tattoos and dumped poverty pack bog stock ecotec V6 VP commodores with dented purple rims ? My mistake!!!
  • Like 2
Nah my brother didn't come [emoji23][emoji23][emoji23]
  • Like 3
Awesome ! Mind to share some pictures of your car ? :)
Looks like a great night last night, Sorry I couldn't make it. We'll organize something after Race Wars.
It's always good when we catch up hey Manne [emoji6] ending with great Nandos as usual [emoji23]
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
