Having some terrible luck with things breaking. In the past 10 days,
had garage roller door fall down. Just fell down again this weekend.
Drawbar on the boat trailer snapped (kinda my fault)
Bobcat starter motor failed
Drivers window jammed on my ute and a heap of oil leaks have started.
And the worst is the solar hot water system has burst and dropped all the water on the ground. Just had to shower at the neighbours :(
And the worst is the solar hot water system has burst and dropped all the water on the ground. Just had to shower at the neighbours default_sad.png
f*knell mate did you build on a sacred site!!
  • Like 1
