Miyazaki
The first thing I check every morning is the news. If we're at defcon 5 I won't be in to work. Taking the skyline for a spin. Hammering it hard to outrun the mushroom cloud. Flight of the Valkyries pumping through the subwoofer!
Haven't driven the Nissan for 3 weeks. Just turned it over. First pop fired straight up. Show us your Nissan! Any one remember the old TV commercials, "it's a Nissan that's my car" to a horrible jingle.
I'd bet mine will be flat when I get home next week
Wow it looks so picturesque down there. Maybe a bit close to North Korea. How is the propaganda in Japan? It's totally trumped-up here?
It was but went quiet. Plenty of Julie bishop on tv
Yeah its picturesque here, but I think it is across all of Japan. Yes not far to korea...
I usually need to jump start mine so I'll be dead for sure
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
