I have to go to the pool at least 3 times a week for the back. I normally do excersize and stretches in the hot hydro pool then go to the 25m pool for walking and swimming laps. I've got dodgy knees too and if I walk too much in the pool they ache real bad but it's only Austio arthritis. I was in and out of physiotherapy for years and just pissed it all off did a load of research and found a balance that works good for me. What is the main problem with the knees?
A few of my mates I played footy with had Osgood/slaters and it finished them. After over 200 games of footy I wish I'd never played but I loved it alot. Football is my family's religion! But I've lost interest over the last few years. Not as hardcore as t-revs with his West coast Eagles engine bay!
Yeah not bad. How was the drive home car still good and did ya hav3le a grin going home thinking I got a 12 sec car
Hey Dean I found a awesomeness little R35 on Gumtree for the boy. Would post the link if I knew how. Have you got any of the r/c's up and running?
  • Like 1
1 hour ago, Beyond Blue R33 said:
DSC_0348.JPGDSC_0347.JPGthe earlier time was the faster. Dropped it to 30 psi all round today. Do you think the duramax 75-90 is the right oil for the diff? It was juddering bad when I changed it then came good with the l.s.d. Paste and figure of 8's? The tein basics have only height adjustment and the ride is hard as since I lifted I't?
Track temp definatly didnt help, colder it gets the less sticky it becomes and less traction u get. Same principle when its too hot.
Diff oil sounds about right, was the old oil burnt? Id day that the shock from spinning the tyres to it gripping proberly caused it to tighten up through heat. New oil and a some maneuvering always helps.
Ur shocks are gonna have more travel due to increased hight, more fluid to move bk and forth within its stroke which will make it feel harder
  • Like 1
Hmm makes sense, that's what I was thinking too much extension and not enough compression in the shocks which would coincide with the longer travel and higher spring rate. When you gradually build up the boost and launch it sweet on the street is the only time you notice it. The old diff oil was clean as. I was also thinking due to getting cold between runs that it was at its minimum viscosity but the thinner the oil it should make its way into clutch packs better?
I watched footy in high school and early twenties. Now I despise it. I'd rather watch netball or lawn bowls
  • Like 2
i watched WM on youtube. there is 26 x 22minute episodes plus there is a movie
i enjoyed the series more than i expected. initial D was better but its still very good. the movie isnt bad from memory either
  • Like 1
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
