where is everyone? been so dead since Martin left...
i hope he didnt take you all to Cairns without me
I thought everyone left because of my horrid social media etiquette. Double posts and under researched and funded questions?
  • Like 1
ill hunt around tomorrow for a better deal. surely someone selling the thin 0.7mm stuff has it cheaper than that.
im also going to get the fire at its absolute max with heaps of small stuff and find out the absolute max temps im going to encounter so i know how much metal pipe i need before i can change to PVC.
Gumtree n facebook marketplace always a good deal if you dig around. [emoji4]
I'm back at work dealing with bullshiht kids behavior shit talk [emoji35] .
Apart from that im a bit devo about my clutch i think the previous owner sold it at the right time.
Coz i only did like 3 launch at 6-7k with min slip and it just sitting that tad higher still bites at 3/5 high [emoji37]
  • Like 1
With more double posts and lengthy paragraphs to explain what normal people could within a sentence. Noobilishious:-( the diary of Anne frank on Sau.
Coz i only did like 3 launch at 6-7k with min slip and it just sitting that tad higher still bites at 3/5 high emoji37.png
it might be nothing...
launch another 10-12 times and see how it goes :cool:
  • Like 1
Just now, pol1on1 said:
Its nonstop nonsense i thought if you dont reacted to it thay stop but this is a New level of bonehead.
i try my hardest to ignore it but i cant bite my tongue all the time.
My work has been busy so I'm happy with that. Been loads of setup and working out new machinery. Plus new office, shop floor, and computer work. Refuse to be involved in any botching, bitching and politicking. Do the very best you can in the shortest amount of time for the maximum amount of money. Have bmx with the kids twice a week and pool three days a week for toasted back. Another novelist's post for anyone that cares to read it!
  • Like 1
the 33 strut towers Without modifying the rear parcel shelf. I put some new rear alpine speakers in the back a few weeks ago and it was a hassle to remove just for speakers. Any thoughts.
Do you know where this bracket is from......
I found it in my box of stuff not fitted to car.
Got a feeling its coz of my adjustable coilovers
is that from the left side of the boot? you put the jack behind it and expands into it holding it firm?
this is how i roll at home except i dont get paid...i just save having to pay someone else
  • Like 1
Nah i dont think so but the jack is in there spaced out tight. Bit of a puzzle for me i wish could go to the mega meet and raid a few r33 to find the location of my stuff.
had the safety manager come out this morning saying that we hadnt done enough hazard reports for the year. the system has been down so until this week they couldnt track how many had been entered.
but on the same page showing how few were done for us... it also showed that he had done fark all too!  so many muppets!!
  • Like 2
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
