$20 general entry ! Who's going and should we organise lil cruise together ?
I would be keen though. Just to see Sau at a event. Top idea Eli. Kudos for thinking of a get together at a event! I Will look up what the track package is.
  • Like 1
Yeah i am a fan of mcm find them quite entertaining so will prob like to go. But depends on work
It's 10am - 4.30 ( hopefully you can make it :) we can do lil cruise together & eat nandos as usual [emoji28]
Are You Keen to do the the race track ? $130 [emoji13]
  • Like 1
Don't have Facebook will get the boy from work to suss out the package tomorrow. Haven't run her since the drags so will check it out.[emoji4]
  • Like 2
I can get it for You and pay me at the event If You want [emoji4]
