Mrs wouldnt lile that, shes a picky bitch. I never did understand why she chose me ?
Sisters boyfriend is a mechanic. Triple car port entry down stairs. Whole bottom floor was garage under the house. 4x2 on top. Garage became, partitioned spray tanning booth (qualified never used), massage and raiki room (qualified never used) full clothes and shoes booth on rotating racks (sheer indulgence) she has a doctorate in education (never used) motor bikes and cars sold and crammed into the last remaining door. I loved the layout of that place. After he had to sell his business to support the first wife while teaching at tafe he done cashies every weekend to hide the money and survive. Sister took care of that. Wish I'd bought it when they sold up. Garage was same size as the 4x2 underneath?
  • Like 1
I need a break from my wife, she makes house hunting so stressfull. We found a house but it doesnt tick the enough space for a workshop box so its a no..... bloody women
1st house? We built this one 20yrs ago and own it. I would love too upgrade but we've never had a single issue with a neighbour police or anything. Nice and quiet except for me!
Never underestimate the value of a good neighbourhood eh?
Moved into my "starter" almost 15 years ago, discovered cul de sac living, will probs die here.
  • Like 2
Have helped the Russians and Asians both sides and across the street and behind with lifts, ute, gardening, lawn mowing, pest control, reticulation systems and rebuilt fences after storms. They like me and are old, let them know when party and 700watts of metal is on. No probs!
  • Like 1
Yeah first house, i dont want to move again. Iv moved every year since iv been here which is 5 times lol i only need enough space to store my box and the car, il have it on dollys while i work on it so i can push it outside in the sun.
  • Like 1
We've been looking at big shed spa and pool upgrade maybe a top story but it is what it is. The older the kids get its becoming more difficult. 4 cars in the driveway already but will hold 6. Skyline and xr8 take top spots!
Belmont school for music and drumming, Como school for golf, wife is at department for agriculture in south Perth and I've shifted to bibra lake. Drive is killing me with tonkin works rat running it.
The wife and I just love our little 4x2. (starter) We have done everything ourselves when we saved up to afford it over the years, bore, reticulation,patio,shed,concreting,paving,fish pond,gazebo,gardens,lawn,driveway, kids were born here, p.l. + l.w. engraved in driveway concrete. Now p.l. and L.l. It's our home not a house.
Painting all the patio pine in the car port then building it. Saving up to buy the metal sheeting, golden memories [emoji4]
DSC_0298.JPGDSC_0299.JPGthe wife me and my dad built that s.o.b. 20 years ago. Hip jointing and angles with circular saw and mitre box with Tennant saw. Skewed nails with no nail gun. Hammer and nail punches. Ladders in sand and rapid set all the posts in. Painted all the pine with rollers in the car port before dad engineered it. Leanne and I were his lackeys, that's what makes it a home and why I'm reluctant to ever sell;-) we were fully broke at the time and dad bought all the sheeting for us as a Christmas gift:-) boxing day dad and I on ladders fitting the sheets. Our family home:-)
110km to work
Takes 70-75minutes but relaxing as never any traffic
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
