I did and tried to call him , must be dating.
All I need is the bush brush but sadly it’s not separate item
, come with the arm. Not in rush , I prob can pick up straight from Japan. And I have a friend who works in nissan Wangara who can install it for me
For 1700 go to Japan and get one [emoji2]
  • Like 1
2 hours ago, ElleAli76 said:
After market? Nah I’m looking for genuine parts , it won’t last long with after market plus it’s stiffer !
Aftermarket is always better.... why fit a hks exhaust if the nissan one is better? Lol
  • Like 1
Now with the exhaust is different , I didn’t go with Chinese brand like what I’ve got now and FYI I didn’t have that install it was from previous owner , it’s still loud but I don’t like it as it didn’t sit very well.
With genuine Nissan’s exhaust yea it’s good but it’s not loud enough like how I want it.
So I go with HKS , it’s loud enough than the current.
Now questions - do I need to re-tuned the car with the new exhaust ? What about the horse Power , would it impact ?
  • Like 1
 A tune is always gonna improvw things, boost + ignition + fuel = power!
Edited by R33kizza
Any internal spare parts Or engine oil I’ll go with genuine , accessories feck I don’t care , so long it’s good quality and kot Chinese emoji28.png
Are u planning on lowering the car? If u do ul need those bushes to compensate for the added camber...
  • Like 1
Nah not really , it’s the clanking noise that I can’t stand and apparently I need those bushes
lol it’s drivable tho , it’s not like a safety concerns. Anyone wants to help me ring japan Nissan’s and found out how much ? My Japanese skills are very limited [emoji23]
Sounds like a task for@t_revz
  • Like 2
