23 hours ago, ElleAli76 said:
Its a date! :D
Mostly because I cant wait to see the look on your face when you see what happens to cake transported on a dirt bike.......
  • Like 4
Its a date! [emoji3]
Hahahahahah use the pizza bag and put the cake in a container !
Just drop the car at galvesport ! wohooooo I can’t wait to see the new exhaust [emoji28]
Then next week Lochy ( sorry Trev ) we have a date ! Fix my car bushes please [emoji173]️[emoji324][emoji8][emoji512][emoji512][emoji512][emoji512]
  • Like 2
So lochy has years of experience in sorting out split open and mongreled bushes. It's a dirty job but someone's gotta do it:-P that's where a red beard comes in handy. Right tools for the job. Oi:-)
  • Like 1
Hahahahahahahahaha you’re so funny !
He works with WA suspension [emoji28]
  • Like 1
So my car will be ready tomorrow , when is the next show shine ? Lol
Let’s do small cruise with Trev
R34 may need some more work going back to Phil for a look over tomorrow paint is going weird [emoji24]
  • Like 2
