fkn frustrated with the car atm, paints gone to shit, alarm is playing silly buggers, and today the indicator decided its not going to cancel any more FFS!!!
That was me a year ago. Me and Dave test drove it. Pulled hard at 7000. Dave broke the ton in a 60zone. Breaked solid, handled awesomeness? Stalling on the way home after purchase. misfire 2 days later, front brake discs and pads died, steering stopped centering, holes in exhaust, radiator shit it's self, immobiliser shut ignition down. Rear seats had no bolts, doors wouldn't shut. Intercooler pipes leaked, tyres had chunks and holes from ridiculous camber. new coil packs, plugs. Oil change. Rack rod ends, castor arm bushes. Full exhaust, new front slotted rotors and pads, lifted ride height, rewired immobiliser and spaghetti under dash. new cat x 2, blew the 100cell ceramic to bits and melted it. New master and slave cylinder sleeved, clutch fork came off pivot ball, new gearbox oil. New diff oil, diff chattering bad, Ford lsd paste fixed it. Stereo crackling and not working, full custom install, new tyres. And foot settings. Air con compressor clutch sized, new compressor. Cleaned Iacv replaced solenoid. A/c whirring noise in dash now and rattling. Revs dropping to 500rpm when a/c fan cuts in. Load on alternator. Rattle near turbo under full load and running rich. Easy outed and replaced manifold and turbo bolts. Blatantly refuse to fix anything else till the turbo fins enter the exhaust. 1 full year of skyline ownership. ;-)
  • Like 1
Its all part of the fun of owning a skyline....
  • Like 1
I can hold my cool for 3 or 4 mins then it all goes in the bin lol
That's why the bouncers took martin's I/d, imagine the big bald headed unit cutting loose chocking the f**k out of a tiny Japanese steering column, scary>:)
  • Like 3
On 12/18/2017 at 7:24 PM, shoey85 said:
R34 the Manual is so good, think my 4th synchro may be on its way out.
215 as an auto then 245 as a manual he said he did see 250 on one run but couldn’t find it, also he didn’t do a full solid power run for show.
Next time or any dyno days coming up would be keen for a run!
Now I want to go for a cruise in the hills!!
Nice!
My old auto on a hot day made ~190rwhp (not that you can compare 2 different dynos), still nice results!
If you wanna go for a cruise we should do it while I have this (it's not turbo though)
  • Like 2
Nice!
Naice!! And yes let’s do it, when you free?
