Had a issue earlier on in the year resulting in having to change the clutch
wile i was there i got some arp flywheel bolts
now the instrusticon say to use the lube on the face and thred locker on the thred
but on the arp website it says not to use togeather
and there seems to be a diffefence of peoples opion on the torque on the bolts
and help would be awesome
Edited by neo32
https://www.sau.com.au/forums/topic/456795-flywheel-bolts/
I would use thread lock ..I would do it up to the tighter torque you found.
Then I wouldn't worry.
Then I would do skids and post vids.
But you already did the bolts right? And shit didn't go poo?
So post skid bids.
https://www.sau.com.au/forums/topic/456795-flywheel-bolts/#findComment-7537203
Don't use lube and thread lock together in the same place. Thread lock on threads will lube them when you tighten them, then will set to lock threads. Lube under the heads will allow torque to be converted to bolt tension.
If using lock and lube you need to ensure that you use the correct torque value (usually 20% less than dry values). This is very important otherwise you will strip bolts.
https://www.sau.com.au/forums/topic/456795-flywheel-bolts/#findComment-7537271
Yep seperate what your applying to.
Threads need lock to hold, under the heads to slide the torque up right.
2 Seperate areas, dont apply both to the same section so they dont mix, its simple.
https://www.sau.com.au/forums/topic/456795-flywheel-bolts/#findComment-7537297
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
