Hi again, I'm getting ready to have the cams I bought installed into the head (motors being built up as we speak) and I'm wanting some suggestions...
I bought a pair used from a member that were suppose to be 264 9.7 cams, but he sent me a 264 and a 256, 9.7, saying the other 264 was rust pitted.
So now I have a 264 and a 256. QUESTION: considering I'll be using my Electramotive TEC2 standalone, the CAS drive is not important to me, so which would you install where? (I forget which one has the CAS drive gear in it)
Like I said, I will not be installing the CAS mechanism, so either cam can go into either side... so which would be better where??
Thanks for the help
joel
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/
Hi Joel, I would go with 256 inlet and 264 exhaust, I have seen this (longer duration exhaust) work on a number of GTR's. What's the lift on each cam? My RB31DET has 268 inlet and 272 exhaust, both at 10.5mm lift.
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-932662
Thank You Sydneykid for the responce. The cams are both only 9.7 on the lift. I had the head set up on a end mill (for the lobe clearnce needed), and the notchs came out sweet ....
I also have the Tomie adj cam wheels to go with the cam upgrade, so if you would, please give me some advice on where to start with the placement of the cams.
thanks again
joel
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-932685
Duration is the amount of the time the valves are open for.
Lift is how far the valves open. Consider it as the washer in your tap; as you turn the tap on further, the washer lifts higher to let more water through. With the higher lift cams, the valves travel further into the the combustion chamber, thus the modification to the head is required for clearences.
As with longer duration cams, higher lift cams have their advantage in the higher rpm and hurt low rpm response. However, how much this rule effect the forced induction engines always puzzled me. Ben is running a huge turbo with crazy cams and has amazing response, does 400cc make that much difference...?
Back to you SK.
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-933140
thanks again
joel
Hi Joel, 256 @ 9.7mm and 264 @ 9.7mm is a good combination, if tuned properly it will make power and run very nice with that combo.
As for cam timing all engines are different, I start at 1-2 degrees advanced on the inlet timing and 3-4 degrees retarded on the exhaust. The exhaust timing makes the most obvious difference to the power, but don't ignore the inlet. It helps the response as well.
Hope that helps :thumbsup:
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-933161
SK,
Interesting that you've found that shorter duration inlet cam works better than the reverse!
Tomei sell two PONCAM setups for the RB26:
Type A - 260 degree, 9.15mm lift intake / 252 degree, 9.15mm lift exhaust
Type B - 260 degree, 9.15mm lift intake / 260 degree, 9.15mm lift exhaust
I went for the Type B set for my car, but was wondering what the theory behind running a larger duration exhaust cam was?
Wouldn't it be best to have a longer duration intake cam to fill the cylinder and push out the gasses out of the exhaust valves as opposed to having a longer duration exhaust cam and relying on scavenging vacuum to suck out the gasses?
Hmmmm...
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-933302
SK, Interesting that you've found that shorter duration inlet cam works better than the reverse!
Hmmmm...
Hi Merli, I didn't really specifically choose the cams, they were available at the time at right price. I was really more interested in the higher lift (and lower price), than the small diff in duration. :cooldance
I have heard and read that longer duration inlet is better for the reasons you put. And they certainly sound valid. I have also heard and read that longer duration exhaust is better, based on the fact that the inlet is under direct boost and the exhaust isn't. So you have to run longer duration on the exhaust to match. I have also heard and read that a longer duration inlet cam makes the engine lumpy, so its not a matter of running a LONGER exhaust duration, but in fact running a SHORTER inlet duration. :confused:
There are plenty of arguments either way, I really have no idea which is correct as I haven't done or seen a proper comparison. I suspect that there may be a boost threshold where the longer inlet duration argument has substance. But I have no proof, it's just a suspicion. :headspin:
Most of the engines I am involved with, I suggest the same duration for both inlet and exhaust cams. Maybe that's the right answer. ;)
https://www.sau.com.au/forums/topic/45784-cam-question-rb26/#findComment-934655
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
