They (Red Cross) work off the model Birds,...
Look > Listen > Link
+ Safety being paramount to the attendee if the distressed person is drug affected
+ Listening Skills
+ Empathy Skills
+ How not to appear shocked
+ Leading questions
+ Leading tactlie support
+ Calming techniques
+ Triage (prioritising)
+ Role Play
  • Like 1
https://www.sau.com.au/forums/topic/458695-p-f-a-course/#findComment-7579328
Should be a compulsory high school course these days with ice abuse seemingly on the rise^
You know I've always wondered why high school curriculum never made way for a general life skills class consisting of things like a first aid course and negotiation, counseling and everyday law, how to buy/sell/service cars etc. The stuff you know you will use in life even if you don't use the Maths that everyone claims not to need.
The closest I had to it was a leadership class, which the principal taught himself and unfortunately you had to choose between that and outdoor education - both useful skills!
  • Like 1
https://www.sau.com.au/forums/topic/458695-p-f-a-course/#findComment-7579352
Negotiation came up yesterday but I was remiss in bringing up any elements in that department.
One person stated that if a fire was looming the word "relocate" was to be preferred over "vacate".
I only brought up strategies on how to befriend the victims' pets as a way to get them to co-operate.
But yes, negotiation skills are super important in assisting the person/people to link.
Most time was spent on rapport building, calming, listening and non verbal cues.
https://www.sau.com.au/forums/topic/458695-p-f-a-course/#findComment-7579837
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
