I've just got a modified standard ECU put in my car.
I've been umming and ahhing about the Greddy emanage and other things but the opportunity to put this in just came up so I went for it.
It's got the limiters taken off it and I dunno what else. Details are a bit sketchy. So far I have noticed that the power delivery is so much smoother than before. I think it's because before the standard ECU was constantly making corrections due to the higher boost.
I would say that the seatofthepants-o-meter is registering a 10-15 kw gain which isn't a lot but the new smoothness means that it feels, and should be, faster. When you floor it in 2nd (or any other gear for that matter but I want to keep my license) you are not sitting at peak power the whole time. By getting rid of the tiny little hesitations as the standard ECU corrected and re-corrected it gets to redline faster. I've hit the rev limiter in 1st gear twice now by accident which I normally never do. (bad me)
So boost cut is gone, speed cut is gone (yay for the Eastern Creek straight) and it only took about half an hour to learn my driving habits and give the extra power over.
Beauty is that the Nissan consult can still be plugged into it and the trannie has no issues whatsoever. I presume I'm going to blow up my diff now.
https://www.sau.com.au/forums/topic/45928-info-for-gtt-tiptronic-owners/
Abo Bob,
you legend, I have been doing lots of research and I couldn't get a straight answer on whether or not it would really work, it seemed the only other option is a SAFC2 which seems outdated now.
What other mods do you have, what boost were you and are you running now?
I have FMIC, 3" exhaust and dump pipe, pod filter, boost at just under 1 bar (14/15psi). I am getting a bit over 150rwkw which seems low due to mods but I seem to be running very rich, I am told that the emanage (excluding ignition harness which I am told won't work on the autos) should give 30-40rwkw if I run 17/18psi when the boost cut is changed? What are your thoughts? Do the R34 turbo's cope with this amount of boost? or does the nylon wheel melt?
Also, as AFRO asked, what did it set you back, and where did you get it done.
Cheers
Cost me a grand as an exchange from Powerplay but it's a bit of a one off at the moment. Give them a call in a few weeks or about a month and mention my car (they know it).
Hunter - That does seem low. I had 162 with less boost. I have Nismo panel filter, CES split dump/front pipe, 3" cat, Fujitsubo cat back which is fairly quiet and an AVC-R for boost.
Just went out for a blat and turned the boost up to 1 bar just to see. Seemed to cope fine although the turbo seemed to be surging a little. I think that's because I don't know how to adjust the boost duty cycle on the AVC-R.
If you consistantly run 1 bar something in your turbo will let go so I'd stick to 0.85 if I were you.
ok,, umm i dunno if this is meant to be correct or not,,
but i got mine dynoed ,, and i was getting 177rwkw, and mine is stock!
except exhaust,,,, standard boost and all,, even down to the factory air filter,,
but it was running a bit crap lately and ecu has error's 17 & 46,, might get it dynoed again,, to make sure everything is running ok,,
it was dynoed in shootout mode,,
edit:- mine is manual,,
AFRO
Abo Bob,
Did you get all the harnesses put in, ie ignition etc... or just the fuel component? I am still considering getting the whole emanage kit and I am assured by Advan (the Trust distributor) that all the components work with the 34 auto and the coil frying problem has been addressed with the latest sw revision.
Now that you have been running with it for a little while is it still running well, is the auto box coping ok? Feeling any faster? I am told one would expect around 40-50 rwkw, what do you think?
Cheers
I don't have the emanage. Advan need to get their story straight. I've been told by one of them there that it will work fine but that you can't use the ignition harness and by another that he "doesn't recommend putting it in there at all."
I have a modified standard ecu.
So far I would say that I'm a little concerned about the auto's power handling abilities. The flaring that I used to get between 1st and 2nd gear when cold only now seems to need to more warming up to work properly. If I redline it however, it drops timing or something, does a little fart out the back and kicks into 2nd beautifully.
I'm going to look into changing my fluid.
Good to hear there is something else out there....the second I get another e-manage ignition harness though I'll put the diodes in and give you guys the details....hoping to get a harness next week...unless one of you guys has one laying around you could sell to me?
Yeah the flaring is easily sorted by a good warm-up....once the car hits temp you don't ever get it.
There are 2 problems with the EManage in autos, the first is the coil frying problem, but that happens to manuals as well. The real problem is it removes the ECU control over ignition on gearchanges, this means you end up with very jerky gearchanges. Plus, with no power cut, the gearbox will wear much faster. Simplkistically this is because the EManage has no gearshift logic.
I believe there may be a cure for problem #1, but I don't see anyway for problem #2 to be overcome with the current logic.
So I am looking forward to your results. :D
how did they do it abo bob? modified standard ecu for skylines. thought that was impossible as no one worked out how to do it properly or am i thinking of r33 gtst when it comes to chipping the ecu?? SydneyKid, help.
if not looks like il be having a chat to powerplay in the not to distant future...
probably a daughterboard.
the japs have been doing it for ages for the 34.
yeah the ecu requires a new chip, the in the 32s you can just download to the existing eprom but the 33 and 34s require a seperate chip.
  • 3 weeks later...
Well I just did a dyno run to find out the following:
1. 189.4 rwkw at 0.8 bar which is up from 162 rwkw at 0.85 bar before the ECU.
2. I'm not sure how to read air fuel ratios. It's between 10.9 and 11.65. Which is leaner?
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
