  • Replies 81
Are you willing to seperate the platic part that holds the electic windows on the drivers side.
I ll take the switches aswell
Sold mate
Do u have A pillar interior trims both sides?
Yep. Got those.
Have you still got the headlights mate?
Hi do you still have the suspension? I am
Not too fussed on condition I am happy with stock leaking parts of that is all you have.
Cheers
Hi.
Do you have a boot trim ?
Best,
P.
All those parts have been sold guys
