Selling my twin setup.
Engine always maintained, oil and filter change every 5000km with Penrite 15W50 diesel, so turbo bearings perfectly clean. Street driven, daily driver with the monthly mountain runs. Never tracked and oil temperature always sat at about 75 degrees never exceeded 90 degrees.
Ran the turbos at 26 psi for a short time but at 23psi for 95% of their lives.
Setup was designed to maximise response with free flowing dumps and front pipe.
Done about 60000 kms
Prices: Negotiable, sensible offers will be considered
Contact me via pm.
Thanks.
TURBOS
2 x Garrett 2860 -5
Heavy duty actuators
Perfect condition
No shaft play.
The rear was rebuilt at 30000km due to oil line issue.
Price: $1500
TOMEI DUMP PIPES
Old style with larger diameter 73mm compared to the newer 68mm from memory.
Highly sort after.
Flanges and welds in perfect condition
Price: $600
FRONT PIPE
Very well made mild steel front pipe
Custom 3.5 inch collector with 3 bolt flange. A bung is on the collector to run a Bosch wideband O2 sensor. Modifications were made to assist response and eliminate the 3 inch restriction on most other front pipes. Will bolt straight to factory position but you will need to weld a 3 bolt flange to your cat back.
I have heat wrap on them at the moment but quite happy to take it off and spray them black for the buyer.
Price: $500
Edited by XGTRX
  • 1 month later...
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
