Details:
brand new Tomei Cam Gear inlet Pulley available
These are the brand new style which are 100% Duralumin
- Cam gears are now coloured Red and Black and no longer purple and red.
Suited for RB20DE, RB25DE, RB20DET, RB25DET, RB26DETT
GTR, GTS, GTT, GTST, GT
didnt use due to retaining VCT
Price 180+postage
https://www.sau.com.au/forums/topic/460211-tomei-inlet-cam-gear/
  • 2 months later...
