Carbon Fibre Group Buy #3 R32 R33 R34 Etc *** New *** 10/25/2015
  • 4 weeks later...
I put up abit ago about if anyone has tried the Australian made carbon stuff? The place is called car mate they are in nsw. Have a look at what they have!! I have a 34gtt and i know they have about 6 or so different carbon bonnets and heaps of other things. They do fibreglass, carbon fiber & silver carbon fiber. Has anybody seen what quality there gear is like?? Cheers
Yeah I've got all the bits minus the side extensions haha.
Was thinking about it but not sure either. Can get a set of those carbons ones locally on eBay for about 500 last time I checked.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
