Hey folks,
I have a 2001 V35, with a sunroof. I'm also 198cm tall.
Since the sunroof opens internally, the roof liner is quite a bit lower in the sunroof model than the non sunroof model. I was wondering if anyone knows if it's possible to lower the seat lower than what the electronic controls will do it? (So I'm thinking take the drivers seat out and remove some spacers or something or take it into the local Nissan dealer and see if they can change the seat runners for something else).
Has anyone had this issue before and come up with a solution? I'd only need 1-2cm more room. I fit in it fine after work, just in the morning I'm slightly taller and it makes my head brush against the sunroof surround ;(
https://www.sau.com.au/forums/topic/460770-drivers-seat-height-in-v35/
no spacers to be removed and I doubt a nissan dealer would be interested in doing anything for you, especially being an import.
I think the options would be to have aftermarket seats fitted, or take it to an auto upholsterer and see if the can remove some of the foam padding in the seat base.
Edited by sonicii
If you've got a V36 then you can lower the original seat slightly :) I did this soon after I got mine as I'm ~192cm and have a sunroof. This is the guide I used.
V36 seat height/adjustment mod
Just had a quick search and found this one for the V35. Unfortunately it doesn't seem like you can get quite as much extra adjustment from dong it in the V35.
V35 seat height/adjustment mod - Look for post by GWord256 (#44) on page 3.
Thanks Heaps.
Mine was a little different. I didn't have that thick metal washer. Only had the rubber and the one with the lip. But i replaced the the other thin one that had the lip on it with a flat skinnier one and wound the nut back so it was just on.
Got a little more room for my head so im happy.
Thanks for that Fri_33! I'll have to try that next week :D (out of town for the rest of this week).
I couldn't work out a google term to find anything useful (including 'I don't fit in my V35 Skyline!'), but I recalled reading something about it being possible when I was first looking at getting the car, but hadn't been able to find where.
No probs, hopefully you can get some more room. Us tall guys have to stick together and try to sort out these issues. I ended up with custom rails in the R33 to get as much room as I could after trying a bunch of different seats :)
I forgot to mention mine is a coupe and I assume all the things I posted are for a coupe also. I don't know if sedans differ.
The only thing I would probably like is to get the steering wheel a little closer to me now. I haven't actually looked to see if there is a similar mod that can be done with that. I'm a little more cautious of messing with the steering wheel. Would have for shafts to disconnect or wires strip from it moving too far. I figure it works in a similar way with the steering wheel with the steering shaft having a spline to allow it to go in and out.
Mine is a sedan, but in one of those links was a series of pictures taken looking through an open back door, so it must work for the sedan too. That was something that I did like about my old Toyota Mark II (Chaser, x90), the steering wheel went up/down/back/forward and could pop up out of the way when you got in and out.
I also find it a bit odd that the instrument cluster moves with the steering wheel in the V35.
So, I've done it. In theory it works, but now rather than the seat hitting a stopper, it now hits against the left hand runner and can't go any lower on the left, but the right keeps going down. I've got maybe 1/2 a cm extra, if that.
Surely you would have sat in the car and tested everything before you bought it. So it's pretty much your own fault
Really?? Ever imported a car before?? Hard to sit in it when it is in Japan... I didn't realise mine had a sunroof until it got here. Pictures and description didn't reveal it. If it didn't have the sunroof, no problem.
  • Like 1
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
