So I just did the belts on the stagea and low and behold whilst flashing the light about I see some bare wires.
I'm assuming it's the knock sensor , it's a two wire plug between the v under the intake. Can be seen from the front in the opening between the heads. One wire is bare other looks to be cut. (Looks like mice got to it :-/)
Car does not ping.
So my question is. Does the intake have to go in order to get to it and fix the wiring ? If so should I just do the rocker cover gaskets(passenger side weeps only just) and plugs 143xxxkm. Or am I going beyond what's needed to get to the knock sensor.
Car goes beautifully just last weekend did 1000km round trip and got 720km out of a tank (ultimate ) with no hesitation what so ever even snapped the speedo on a overtake.
Thanks for any and all advice.
Edited by malialipali
Surprisingly common, I have had to repair a few. I should have a spare knock/injector loom here somewhere if you can't find something local.
Yes the lower plenum needs to come off to replace it.
Nice and warm Dale, for many hours. Smart little f*krs would just nest it out with rags and grass, anything they can find to make a cosy and protected home.
As soon as the door unlocked they would know to scurry away.
Is the wiring shielded? If not I can repair the plug thats not an issue. If it is shielded then yes I would need the part.
Is there a part # ? Same as the VQ35s? by any chance. Is this the guy I'm looking for https://www.z1motorsports.com/oxygen-and-knock-sensors/z1-motorsports/350z-g35-vq35de-knock-sensor-sub-harness-p-5833.html?osCsid=keol7gu21kictn9cop24pqrhb4
If I cant find anything by end of tomorrow, I'm happy to pay what it cost + express bag postage Scotty.
OK just did a quick google (currently at work so cant dedicate too much time) looks like 50ohm RG58U coax on the positive side. 99% confident I can repair it. So will give it a crack to repair the wire.
If the car ends up off the road for a few days so be it - ive got a spare.
Cheeky little feckers they are...
I was actually joking when I said looks like mice got to it o.O , now I find that this is actually true and common. WTH!
May as well dot the plugs since I'm gonna spend next Saturday over an engine bay.
Anything else I should to preventative wise. Not fussed on $ , I'm driving the car to Adelaide next month and need to make sure its healthy.
Thanks a bunch on the help All .
You had better get it apart and see what's broken first, you may need the knock sensor too.
Yes, that loom looks similar, on ours it's wired into the injector harness, but you can simply run that one in addition to replace the chewed out part.
  • Like 1
So spent most of the day (38C here today) over the engine bay listening to tunes and drinking beer.
Stripped the intake off, rigged up a hose to my wet and dry vac and vacuumed up sand/ grit, dirt 2 snail shells ??????? (where the hell do they come from) from around the intake before taking it apart.
Cleaned the intake sections with carb cleaner . Got the harness out and assesed. Looked like shit!. stripped it back de-pinned the connector. Soldered in new leads. Coax wire was perfect fit. Soldered the pins and reassembled the connector.
Knock sensor tested at 562K Ohm (well within the range). With the harness it tested at 559K Ohm still in range.
Did the spark plugs at the same time, who ever did the car last should be slapped !!! had Champion Platinums in there with a 14 (NGK4) heat range .... way too hot , guess they whacked in 350 plugs, electrodes were worn to heck too probably 1.4-1.5mm gap. Got some LFR6AIX.
Put it all together and the moment of truth, fired up first go. Went for a test run , Significant improvement on take off, tried stalling it up and lit up the rears ! never happened before.
I think I just thought these cars were good at WOT and sluggish otherwise......... proven wrong now. Very very happy with the improvement.
Thank you all for your help , Esp Scotty for telling me the whole intake needs to come out.
Total cost $123.70 including the plugs (had to buy the coax and I ran out of heatshrink)
  • Like 2
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
