I have listed on Ebay.au:
http://www.ebay.com.au/itm/231769583058?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
I am offering a R32 GTR Shock Absorber & Spring Package (BNR32GTR) for sale. This kit was developed for a group buy on the Skyline Australia Website.
  • The 4 Bilsteins are new and were re-valved by "Sydney Kid" for Australian Roads and Track Days. Extra grooves for circlips were added in the shock body for ride height adjustment
  • The Whiteline Springs in the package are the springs specified in the group buy. The springs have been used very little and have the normal paint chips and scratches you would expect. (See Photo) These Springs are no longer available.
  • The Super Pro polyurethane bushings and caster adjusters are new in the original packaging.
  • The bump stops are new and modified per the group buy specs. The white bump stops are discolored by the black sleeves. (See Photo)
This is an excellent package for the R32 GTR. A great balance of ride quality and performance.
The link to the SAU.com.au website has lots of information on these items and setup.
Roy Campbell - Mobile 0449977645
post-58563-0-72277300-1449042636_thumb.jpgpost-58563-0-02052800-1449042672_thumb.jpgpost-58563-0-07795000-1449042705_thumb.jpgpost-58563-0-70326400-1449042736_thumb.jpgpost-58563-0-20317400-1449042767_thumb.jpgpost-58563-0-72080000-1449042798_thumb.jpg
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
