I am sick of this stuff in my garage now...
Stock R33 GTR BOV's - Not sure what they are worth, so I will say $150
R32/3 GTR HKS pod filters (with dirty elements and no brace thingo's) - $100
GTR seat covers - $50
HKS 60mm Boost and Exhaust Temp gauges with recall. These are in a GReddy pillar mount for an R33. Includes all wires etc. the lot for $500. They are still in the car, so i'll need notice to take them out.
I will add more later.
Christian
https://www.sau.com.au/forums/topic/46145-garage-cleanout-sydney/
