I have a T67-25G turbo for sale, has a 8cm^2 exhaust housing, has just been checked out and had the wheels machined and balanced so all is ok and is ready to use, rated to 550hp and would be perfect for rb25 or rb20/sr20 due to the small exhasut housing, now $1100
will post pics tomorrow of it now, email [email protected] for more info, in adelaide but will ship at buyers expence
https://www.sau.com.au/forums/topic/46156-trust-t67-25g-turbo/
As measure by Doughboy, copied from a thread on turbo chart in Performance section
Comp wheels same
Exhaust wheels
TD06: Minor 56mm, Major 65mm, Trim 74
T67: Minor 54mm, Major 62mm, Trim 76
so they are a very simailar turbo with a exhaust wheel that flows al little more so it should make a little more power, but the smaller exhaust hosuing may reduce the power a little although reducing the lag as well, so it should do 330rwkw in my opinion looking at other peoples results
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
