  • Replies 169
Can we get a mother f@cking moment of silence for this small cronic break ...... LoL  Sorry im bored at Uni
I HATE UNI (exams anywy)...i've got end of year exams starting on tuesday and havent started studying. oh well ill fail. instead of a 3 year course it may be a bit longer.
DUDE more than happy to chip in for the petrol if u give me the seat........... SO I AM IN??????? Thanx nick much appreciated as the good old GSR aint gonna make the trip as it is sorta DEAD....HAHAHAHAHAHAHHA
Cheers mate
Ando
B.T.W. i'll give u a buzz Sat and organise a time.... you could pick us up on your way to Burger King....you go straight past my place to get there!!!! Which ever i'll call ya tomoz about it!!!!
400HP & By By, im definately not going to Terry Hills, who lives up in those hills anyways! :D
11am at crossroads sounds easy. i'll leave my place by 10:15am
wot we could do is meet just after the toll gates on the M5. more central to everyone? then, cruise down the M5, take the liverpool exit and its 10mins on the hume highway to the meeting point at the crossroads...
MRTRBO, yeah i saw the stove top lights and said this'll be interesting :) turned onto the M4 and saw you followed and i quietly said yippee :lol:
.6 litre MIVEC engine for only $1100!!!!!!! with gearbox
god damn thats cheap for a 175 hp engine. wjem i was thinking about an engine swap, a while back, all the good honda engines were $1800+ and they didnt put out that HP. hopefully Ian will get it and have a nice GSR sleeper
Originally posted by [MRTRBO]
Can we get a mother f@cking moment of silence for this small cronic break :headbang:...... LoL  :eek:  Sorry im bored at Uni !
Can we get a list of whoz Coming ????
Im gonna be at Cross Rdz At 11am
Might Go down merryalnds way in tha morning to pick up a friend
If so ill give u a buzz Daniel and we can Meet up like before hand like last time yeh ?
:D
If your coming down my way to pick up your mate- give me a buzz and will meet at Maccas like the last time- sounds good
wow. all i can say is "hectic"
meeting at the crossroads was great. met a few of the forums guys that i haven't met before which was great. most made it to the lighthouse, and then we just started getting smaller and smaller from there.
400hp and i ended up cruising with the DTM forums crew, had lunch in town and then headed south for a hit down the freeway and then back up to cronulla, kurnell and then home...
will upload pics later...
Mark: we headed straight back down the princess highway, the traffic was a pain.
Franks: did you get a decent motion shot of me on the way to the gong ?:D
Was a good turnout, although could have been better if we had a fixed spot to meet and maybe done it earlier
a good day all in all:uh-huh:
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
