Hey guys im new here just bought my second stagea which is a 250t rs4 m35 my last one was a c34 rs4 rb25det had all the goodies etc on that and knew my way around it well , but this newer version not so well . I am in Christchurch New Zealand and there isnt much info that i can find around here on these cars mine has a terrible knock in the front end its almost a rattle constantly as our city is f#@ked from the quakes so doesn't help. I can see that one of the wishbone rear bush is cracked and worn and the other side doesn't look to flash either has anyone had similar rattling knocking noises too is there anyother models ie skyline v35 that shares the same front end am thinking of replacing the sway bar links but these look odd comperd to the 2wd version any help would be great , thanks
https://www.sau.com.au/forums/topic/463315-m35-awd-front-suspension/
Go to Cockram Nissan ask for Dan in the parts department (he is a member of Skylines Down Under) and see if he can help you. Or you could ask Dale on this forum if he can supply the bushes. He will have the sway bar links (Whiteline not OEM).
I'm on hols currently; but I'll happily help you with part numbers etc if no one else comes to the rescue in the meantime.
  • Like 1
hey guys thanks for the reply's i was able to buy the oem links from cockram nissan luckily they had them in nz so picked up today as well as new bushes for the wishbone arms fingers crossed these fix the knocks in the front . will be reading through the rest of the forums as i am keen to do some mods to this and see what power i can make from it its a good sleeper. cheers
  • Like 1
  • 3 months later...
What's the general consensus on rubber bushes over neoprene bushes ?
I started pricing nolathene, but saw a few negative reviews, same deal with superior, and whitelines website confused me (mind you, confusing me isn't difficult)..
I am needing to do the front end bushes, and figure that if I am doing the front, I may as well do the rear..
Always open to suggestions and recommendations..
Cheers in advance
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
