hey all.
opened up my fuel tank the other day to check the sender all was good, but now on prime my fuel pump is making a sick noise
now bear with me here this is gonna sound strange...
its usually just a priming noise with one note but after fiddling in the tank when priming it sounded different like a two note slower noise,
after driving around for a while i stopped and tried again and it sounded normal again and i was happy
but when i got home i tried it one more time and its makeing the bad noise again.
am i being overly worried or could the pump be on the way out?
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/
hey all.
Hi Jimbo,
#1 rule with fuel pumps, make sure it isn't touching anything in the tank (like the bottom) otherwise the noise will drive you crazy.
#2 rule, make sure the clamps and brackets are tight, otherwise it will move around until it rests on something and the noise will drive you crazy.
#3 rule, if you suspect the fuel pump, check the fuel pressure. Best done at the fuel rail, on the dyno with a good load on and some boost up.
#4 rule, don't post something up at lunchtime and complain if no one answers before afternoon tea. Some of us have to work you know. :)
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-941732
thanks for the reply SK it helps me understand more but dosnt quite answer my question about the 1 or 2 note prime, is it understandable, i know it sounds silly.
i have a PFC and the controller is telling me that the injector cycle is working perfectly could that mean that the pump is too?
5 hours is a long time to wait when you're stressed, but i get ya :)
thanks cheif
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-941765
thanks cheif
Hi Jimbo, sorry I have no ideas about "2 notes", my family reckon I'm tone deaf anyway. It is usualy related to how hard it is resting on the bottom or how much fuel is in the tank and covering the pump.
The Commander tells you what the ecu is telling the injectors, not what the injectors are actually doing. Fuel pressure guage or a quick a/f ratio check on the dyno will do that.
"5 hours", I've been stressed for longer than that pumping up a flat tyre by mouth. :jk:
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-941808
:bahaha: :)
alright 2 tone expaination
when i turn to ignition the pump will prime "beeeeeeeee"
the problem i am having is its now going a bit slower and as well as going just "beeeeeeeee"
its now going both "beeeeeeeee" and "booooooooo" at the same time
MMMMMMMMMM?
Does it make the "beeeeeee" noise when the engine isn't running?
Or when cranking?
Does it make the "booooooo" noise when the engine is running?
:headspin:
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-941859
  • 3 weeks later...
Hey Jimbo, did you sort this problem out???
I put a gtr pump in my r32 gts-t, it seems to make the same noise as your saying on prime, but when it idles it pretty quiet, but if i just tap the accelerator it makes the loud noise again, it that happenig with you too??
I dunno if that makes sense
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-970123
gday yogi
problem remains but i can see no evidence that its doing anything wrong, car runs as normal, it does it on and off and i cant see that its actually causeing any problems, everything run perfectly so i've just decided to live with it, until i open it up again to have a look.
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-970382
turn your stereo up and the noise will go away :):(
nah seriously, if the noise wasn't there before you fiddled with the system, then you have done something to it. it may not affect it at all, so don't worry too much.
if it were me, i would open up the tank again and repeat whatever you did the first time but TAKE EXTRA CARE to put it all back exactly as it looks like it should go. if the noise is STILL there..... use the "stereo interference" method :)
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-970820
Hey
I finally fixed it!!! Got rid of it and it almost sounds like the stock pump, very faint sound now. It took me 3 goes to get it in the right position, plus i also put a rubber in between the side of the pump and the bracket. Its finally sounding good. (thats a r33 gtr pump)
https://www.sau.com.au/forums/topic/46344-fuel-pump-noise/#findComment-972456
