Clean the car ? I knew it [emoji22] I can't do it till the 21st then , I have Des Wong coming again to do full Polish on the 21st April, meanwhile I have to keep these stickies in the drawer [emoji24]
You don't need to wash the car - just windex / glass cleaner the window before you apply the sticker.
1st pic for me !
2 different sizes , small or big one ? Lol sorry for asking too many questions , just want to get it right and form with everyone x [emoji13]
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
